PLATOS ALESIS DM10
Koyotebox
por el 08/01/2021
MUY BUENAS ME GUSTARIA SAVER SI MI PLATO DE CHARLES LO PUEDO CONFIGURAR PARA UTILIZARLO COMO CRAS Y SI TIENE PARADA UN SALUDO Y GRACIAS POR APORTAR ESTE FORO TAN ALUCINANTE
  • -25%
    287 €
  • Sabian Rock Crash 18” B8X
    120 €
    180 €
  • Vendo kit de bateria
    1.000 €
Antonio btk
por el 09/01/2021
Que tal si pruebas a conectarlo a una entrada de crash de tu modulo y probarlo saludos
beto_drummer
por el 09/01/2021
Hola Koyotebox, tengo otra batería, una Medeli y puedo asignarle a todos los cuerpos cualquier sonido que quiera.
Según entiendo, hacer eso es muy común y suele poder hacerse. Simplemente cambiando el sonido a ese "PAD" (en tu caso el hi hat).
Si sabés ingles, seguramente esto te sirva:
Alguien escribió:
EDITING INSTRUMENTS IN A KIT
  1. Press DRUM KIT to go to the Main Screen.
  2. Press EDIT INST. The top of the screen will show the number and name of the Kit whose Instruments (drum voices) you will be editing.
  3. Select INST (F1). The new screen will show:
    a) the trigger Voice you are editing (the Kit number and name of the Voice will be shown)
    b) the Layer (each Voice consists of two layers, each with its own Instrument)
    c) the Category (the type or "class" of drum sound currently assigned to that Layer)
    d) the Instrument (the drum sound for that Layer)
  4. Select the Voice whose Instrument you want to change by pressing NOTE CHASE then striking the desired trigger. Alternatively, you can highlight the Voice (next to the Kit number) using the CURSOR UP / DOWN buttons to highlight it and use the VALUE UP / DOWN buttons or VALUE DIAL to change it.
  5. Select which Layer of that Voice you will edit by pressing EDIT INST. It will toggle between Layer A and B.
  6. Select the Category you want to assign to that Voice by pressing CURSOR UP / DOWN to highlight the Category field, then use the VALUE UP / DOWN buttons or VALUE DIAL to change it.
  7. Select the Instrument for that Layer by pressing CURSOR UP / DOWN to highlight the Instrument field, then use the VALUE UP / DOWN buttons or VALUE DIAL to change it. To hear the currently selected sound, strike the corresponding trigger or press PREVIEW on the module.
Asi mismo, te dejo otra aclaración (en ingles):
Alguien escribió:
Note: The available Instruments for the hi-hat and ride cymbal Categories are pre-defined sets of sounds designed to work together (e.g., the hi-hat can produce open, closed, "chick" or splash sounds). You can assign any Category or Instrument you like for the hi-hat and ride cymbal triggers, but because other Instruments are designed to work differently, the results will vary.
Este último aclara la pregunta que hiciste sobre si tiene parada, y tendrías que probarlo, ya que el manual que cada "instrumento" (voz) está diseñado para trabajar distinto, por lo cual los resultados pueden variar.
Zone_0
por el 09/01/2021
Configurar como crash, por supuesto que si. Que tenga parada, no creo. Aunque el pedal de hat, si puedes asignarlo para que sirva a ese efecto. Saludos y salud
Koyotebox
por el 01/02/2021
MUCHISIMAS GRACIAS POR LOS COMENTARIOS Y PERDON E ESTADO AUSENTE ME PONDRE CON LO QUE ME AN APORTADO Y OS IRE DICIENDO MUCHAS GRACIAS
beto_drummer
por el 11/02/2021
Koyote, es un placer intentar ayudar.
Por favor, como bien decis, comentanos los resultados ya que tal vez le puede servir a otra persona. :baile::batera:
Stam
por el 29/09/2021
Yo tengo una DM10 de 2015 y no sé si los platos habrán evolucionado mucho, pero la función parada es cosa del plato, no del módulo. La mía tiene 2 crashes y sólo 1 tiene esa función. Ni el ride ni el hi-hat la tienen. Al plato le puedes poner que suene como cualquier cosa pero si no tiene el captador no funcionará.
