EVANS SACA NUEVOS PARCHES
por el 16/08/2005
Buenas, no se si alguien lo habra visto, pero no he visto nada sobre este tema por aqui, asi que aqui va: EVANS ha sacado una nueva serie de parches, los EC2 (edge control 2 plies), que vienen a ser como los G2 pero llevan una especie de sordina en plan como el EQ3 para bombo. Prometen bastante y su mayor baza parece ser la de funcionar muy bien tanto a altas como a bajas tensiones de afinacion.
Aqui teneis la info de la web oficial:
http://www.evansdrumheads.com/EVANewsDetail.aspx?CodaID=5879
Aqui uno puesto en un base de 16":
http://www.evansdrumheads.com/Discuss/download.aspx?id=155&MessageID=21726
Y aqui los comentarios al respecto del propio admin del foro de evans, un tal Mike Robinson que seguramente sepa un rato:
"Mike Robinson" escribió:
Hello All,
Mike Robinson here...the Brand Manager for Evans. I'm sure some of you might remember me from the darker days of DrumTalk (good to see you back, Harry). Just thought I'd jump in briefly to offer a little more in-depth of an explanation with regard to the EC2. Obviously, no single drumhead is going to be the "fix all" solution for everyone, so the only way to know whether the EC2 fits your personal taste is to give one a try. You'll likely find them soon at professional drum shops around the US, where they may wind up on an in-store kit so you can try before you buy. As noted, the sticker price on these are a little higher than average, so if you have the chance to check them out on a kit before you drop the $...it's a good idea. Anyway, here's the concept...
Age Old Problems - With regard to 2-ply tom heads, there are two relationships that will make or break the quality of sound you get. First is the relationship between the head and bearing edge. Okay, no surprises here...but it's an important point. The minute you introduce another element between the head and bearing edge, whether it be a flap that rides between them or glue between the plies, you disrupt the ability of the head to vibrate naturally. The motion of the head is restricted/compromised at its most crucial point. Tune this type of head high and it chokes. Tune it low and it gets tubby or flappy sounding.
The second relationship is between the two plies themselves. A good sounding two-ply is the result of the two pieces of film being able to vibrate freely from each other and also "in-phase", which means at the same frequency. If the two plies were to immediately vibrate out-of-phase, or at opposing frequencies, they'd cancel each other out and you'd be left with a dull and lifeless sounding head. It's important to let the two plies vibrate freely and in unison for the first 4 modes of development, wherein lies the attack and fundamental frequency (or pitch). After that, the plies should start to cancel each other out...which is why the sustain drops off more suddenly on a two-ply compared to a single-ply. Unfortunately, this relationship is disturbed when you put something between the two-plies...like glue (pardon the obvious reference here). Immediately, the free vibration of the two plies is limited and it's much harder to excite those first 4 modes. The result is a lack in dynamic range. You need to hit these types of heads hard to get the whole drum to resonate. Soft dynamics result in a "ticky" top-head sound with very little movement of the air-column inside the drum.
After I explain the following...I'm sure some of you will come back and say it's all marketing spin. That's fine...and we certainly ARE using this information in our marketing of the EC2...but it's also the honest design intent behind these new heads.
The Solution - "EC" stands for "Edge Control". The intent is to boost attack and low-end response, and to isolate higher frequencies and remove them without significantly degrading sustain, drum resonance, tuning range, and/or dynamic range. To accomplish that, the EC2 features a ring mounted on the underside of the head (beneath both plies...not between them) and does NOT come between the bearing edge and the vibrating membrane. Depending on the bearing edge shape and shell dimensions, it floats roughly 1/4" away from the edge (see attached image). Already, we've avoided the two pitfalls mentioned above. We've avoided interfering with the relationship between the head and bearing edge, and between the two plies. We also made the ring width proportional to the head diameter...so the character of sound remains consistent across all drum sizes. Lastly, we cut "stress-relief" slots in the ring (note concentric segmented slots/gaps in the center of the ring). Those slots (similar in principal to our Power Center snare heads) allow the ring to flex with the vibration of the head. When combined, all these design features give the EC2 a broader tuning and dynamic range, and accentuate attack and low-end frequencies. The head and drum respond with the same feel and tonal character (good frequency spread) in extreme tuning and dynamic ranges. Just tap the head softly and the drum still sings. Hit it hard and it's just a higher volume version of itself. Tune it high and it won't choke. Tune it low and you'll get fat bottom-end and crisp attack without the tubby sound typical of traditionally damped heads.
Sorry for the ridiculously long-winded explanation, but I felt it important to share the concept with you. Again, the EC2s are not intended to be a fix-all for everyone. You'll have to check them out and see for yourself whether they match your personal taste. But I want to be clear that there was no copying of anyone elses designs or concepts. We worked hard on this project for 5 years before we felt satisfied to launch it. I hope some of you like it. We're certainly proud of it.
Thanks,
Mike
A ver si alguien se entera de como se pilla esto porque puede ser interesante probarlos. En music123 creo que ya estan a la venta pero no esta la cosa como pa pedir un juego de parches a los USA...
moderndrummer
por el 16/08/2005
a ver si alguien los prueba ,aunke eso de la sordina,no se yo,supongo ke dejara un sonido mas seco,no se los g2 van de pm.salu2 :wink:
dabizon
por el 17/08/2005
seran mu caros?
Pollito
por el 17/08/2005
Haber si alguien los prueba y nos lo aclara, pero me da a mi que el tema de la sordina va a apagar demasiado el sonido.
Un saludo. :)
por el 18/08/2005
mmm, tienen buena pinta, pero no seran demasiado apagados??
saludos :birra:
drumhead
por el 22/09/2005
muy muy buena pinta hacen estos parches!!! pero me da que van a aser chungos de encontrar por aki. Si ya me volví loco en su dia para encontrar un e-mad para el bombo (al final me pillé un EQ3) imaginate estos....
peo weno que yo si los encuentro me los pillo FIJO! que ahora tengo que cabiar parches!
Drum
por el 24/10/2005
http://www.tamtampercusion.com/_noticias/noticia.php?id=43&pag=1
alguien ha catao esos dos modelos?
pa bombo el emad y pa toms los ec2....
tienen guena pinta y kla descripcionq ponen los d etamtam es tentadora...
EC2:
Desarrollado junto al baterista Bob Gatzen, el EC2 se caracteriza por un mufle controlador que actúa sobre la vibración final en lugar de eliminarla. Este mufle aisla y regula los armónicos agudos, realza el decay final de las frecuencias graves y el ataque, permitiendo un amplio rango de afinación. A diferencia de los parches convencionales, el EC2 no "mata" el sonido de las afinaciones agudas, ni pierde el cuerpo en las graves.
EMAD:
Esta serie tiene un diseño radical. Tiene dos apagadores montados exteriormente, lo que te permitirá cambiar de sonido en unos pocos segundos sin tener que desmontar el parche. Esto hace que no solamente enfatice el ataque natural sino también que tenga un amplísimo rango dinámico. Podrás afinar tan bajo como quieras sin tener “ruidos” en tu parche.
alguien los ha catado ya????
esq tengo q cambiar los batidores en un tiempo cercano y no se si probar...
la pega q no son baratos q se diga... :roll:
fraga1
por el 27/10/2005
precio de los ec2
Si os meteis en la web de tamtampercusion, podreis ver los precios de los ec2.
http://www.tamtampercusion.com/_tienda/listaarticulos.php?fam=4&subfam=Tom&mar=Evans
Si no teneis ganas:
08'..........15.30 €
10'..........15.30 €
12'..........15.70 €
13'..........15.95 €
14'..........16.55 €
15'..........19.10 €
16'..........19.55 €
Drum
por el 02/11/2005
alguien ha catao ya estos pacrhes?
estoy batante interesado en ver como tiran pa pillarmelos :wink:
por el 02/11/2005
Gastate las perrras y nos cuentas como van, pirataaaaaaaa :twisted: :twisted: :twisted:
por el 05/11/2005
venga Mario... ke despues nos lo cuentass :twisted: :twisted:
epo
por el 16/11/2005
los tengo pedios
holas
yo los tengo pedios a ver cuanto tardan en llegar
ya os contare
chao
Ppda
por el 16/11/2005
Re: los tengo pedios
"epo" escribió:
ya os contare
La comunidad bateristica te lo agradecera, a ver si realmente son buenos, de todas formas, siendo evans, seguro que estan testeados, y es comprar sobre seguro.
Drum
por el 25/11/2005
q tal esos ec2???? queremos info a la de ya! :lol:
zenith
por el 27/11/2005
bueno pues yo me piyes esos parchecitos el viernes y los monte ayer y bueno teniendo en cuenta que el parche aun no se ha asentado del todo y demas, el sonido es matador!! a mi realmente me gustan porque puedo afinar un poco mas alto que con los g2 y no pierde nada de nada, tiene un sonido bastante bonito y cañero. Yo diria q estan entre unos pinstripe y unos g2. Los armonicos del timbal los deja bastante suave pero bueno aun no he probado otros tipos de afinaciones, probe una y me gusto xq tenia cuerpo y bastante atake pero esta semana seguramente probare otros tipo de afinaciones para ver bien hasta donde puede llegar este parche. buen precio y buen sonido. totalmente aconsejable
epo
por el 29/11/2005
holas
holas
toma ya !!! da gusto oir esas cosas
yo creo que va a venirme guay para mi cama media pearl sbx de abedul lue voy a poner a los toms ec2 arriva y diplomant de remo abajo parche controlado arriba y parche finito abajo
a ver si pronto os puedo contar
chao
Alberto Alvarez
por el 25/12/2005
alguna opinion mas sobre estos parches?necesitamos info
cyblo
por el 13/01/2006
Los EC2: Simply Brutales!, ayer los monté en mi Ludwig Classic maple y he ganado en pegada, ataque, cuerpo y graves, sin pagar el sonido.
Son del estilo de los Pinstripe pero con un ataque mayor y algo mas de armónicos. La sordina es curiosa pero gracias aeallos le he sacado mas cuerpo y pegada a mi nueva Ludwig.
No son para nada como los Hidraulic o Remo Ebony, pq dejan armonicos y no apagan para nada el sonido.
Os los aconsejo si os gustan los sonidos con mucha pegada y graves con pocos armonicos.
Por cierto los precios de Tam Tam son cojonudos (2 € menos q en Alemania)...
Eso si si os gusta el sonido mas agudo no los pilleis... :roll:
Drum
por el 13/01/2006
yo los estoy esparando de tamtam.....aver cuando me llegan q los tenian q recibir.
estoy impaciente. :P
Antonio
por el 14/01/2006
si? a mi el sonido del hydraulic en mi batería me gusta... este es más o menos por el estilo? es que meda miedo no poder controlar los armónicos, y otra pregunta, que resonante le pondrías?
Drum
por el 14/01/2006
antes yo llevaba los G1, ahora tengo puestos los evans resonant black y esos se van a kedar pq dan tol power :twisted:
Drum
por el 31/01/2006
bueno ha salido ya mi pedido de ec2 de tamtam hoy.
mañana llegaran, los catare a lo largo de estos dias y a ver q tal tiran en la sonor.
ya os contare :wink:
Antonio
por el 01/02/2006
sisisisisisisisisisisisisi
ya me diras drum tiu si se merecen mi respeto o si se les puede sacar tranquilamente el cat2....
Ppda
por el 02/02/2006
A ver que tal te salen y lo comentas, porque deberia de cambiar mis parches y no me acabo de decidir. Saludos!
helkia
por el 02/02/2006
wenassss.
A ver, hace 2-3 semanas me pille los ec2, y suenan cañon, lo unico que pasa es que me queda aprender a afinar bien. Hasta ahora tocaba con los parches de fabrica de la Rockstar y le ponia aros apagadores a los timbales y no estoy acostumbrado a los armonicos. De momento he conseguido afinar el tom de 13". Eso sí, suena que ti cagas.
Ademas, esteticamente visten más los timbales, se ve la sordina interior plateada mu chula.
Total, que son unos parches que recomiendo. He usado pinstripe y g2, y estos ec2 les dan un par de vueltas.
Y para nada apagan el sonido, lo controlan.
Una prgunta, ¿que parches pondriais abajo si quiero los armonicos justos y un sonido gordo?
Gracies
