MILLENIUM MPS-400 , Tribal Drumtrack o Alesis DM6
KeSpyKe^
por el 08/11/2009
bueno, tengo que comprarme una bateria y tengo un gran dilema entre estas 3 opciones:
-Millenium MPS-400
-Tribal Drumbtrack
-Alesis DM6
el caso esque se parecen todas bastante, aqui va todo:
Millenium MPS-400
complete stereo electronic drumset with new drum brain, 307 sounds, 20 presets, 30 user kits and 50 preset songs (play along versions). 1x stereo rubber snare drum pad (centre/rim), 2x stereo cymbal pads (bow/edge) with choking capability, MIDI in/out, USB port, 3x mono rubber padded tom pads, includes complete drum rack, hi-hat controller (with half open feature) and bass drum pedal.
Tribal Dumtrack:
4 pads de batería, 3 pads de plato, 1 pedal de control Hi-hat, 1 trigger para bombo • 215 sonidos • 20 Kits preset de batería + 10 Kits de usuario • 50 canciones predefinidas • Conectores de salida: Salida MIDI, control Hi hat, Hi-Hat, crash, ride, caja, tom 1, tom 2, tom 3, bombo, salida de audio estéreo (R&L/mono), entrada auxiliar. • Pedal de bombo, baquetas y adaptador de corriente incluido.
Alesis DM6:
Alesis DM6 E-Drum Kit, Five-piece complete electronic drumset with DM6 drum-sound module, module contains 108 top-notch drum, cymbal, and percussion sounds, Realistic, natural-feeling playing surfaces, 15 programmable drum sets, Dual-zone snare pad for rim click and rimshot capability, USB-MIDI output for use with drum-module software, Connect your iPod or CD player and mix it in with 1/8" input, Velocity sensitive for natural, musical response, Comes with bass drum pedal and drumsticks, included Drum Rack, 1x Kick Pad (with pedal), Pedal hi-hat controller (open/closed), 1x 8" Dual-Zone Pad (snare), 3x 8" Mono Pads (toms), 3x 12" Cymbal Pad (hi-hat, crash ride).
dicen que la Alesis DM6 tiene mejor mod y creo que es lo mas importante, no lo se, si alguien me pudiera ayudar:)
muchisimas gracias.
carioco
por el 08/11/2009
Hola de nuevo; Yo creo que la Millenium es la mas conveniente. Ya que mas tarde podrás modificar los pads y ponerlos de malla. Pero es mi humilde opinión. Yo uso una Roland TD 3 y no controlo mucho el tipo de baterías que comentas.
Insisto en que en el foro tienes infinidad de información de esas baterías.
Ánimo y a darle caña
Carioco :bien:
YEREN
por el 19/02/2010
mi mps-400 tiene 4 dias y estoy muy contento pero como seas un poco alocado enseguida ya
empiezas a querer mejorar cosas y al final te das cuenta que vale mas la pena comprarse la
que tenga mas posibilidades de expansion y la mps tiene muy poco que ampliar por falta de
entradas piezo-piezo. saludos
drummer723
por el 19/02/2010
yo tengo la tribal, y francamente, nunca espere tan buen resultado, no se si se podra tunear, pero repito, estoy supersatisfecho ^^
neil_bcn
por el 19/02/2010
pistas...
millenium mps-400 = tribal powertrack = medeli DD506 = session pro DD506 .... etc
millenium mps-300 = tribal drumtrack = medeli DD505 = session pro DD505 .... etc
asi que elegir entre la millenium que comentas y la tribal.. es como elegir entre la 400 y la 300
a partir de ahi... eres tu
