Conocen esta bateria Sunlite, veanla sin compromiso
por el 18/03/2006
Hola me gustaria que me dieran sus opiniones me quieren regalar esta bateria queria saber si son buenas, el que me quiere regalar me pregunta, bueno espero su ayuda gracias amigos.
Es está:
The 9 ply shells have maple exteriors with basswood interiors. This combining of shell materials produces more complex tones with more complete harmonic properties. The basswood inner layers provide fabulous projection and clarity, while the warmth of the maple exteriors add balance and sustain. The 6?"x14" 10 lug matching snare is fitted with our lateral throw S-05 pro strainer; and each drum has 2.3mm triple flanged super hoops. (natural wood bass hoops add a touch of class) In addition to the 7 standard transparent lacquer finishes, Studio buyers can even special order their own custom finishes and shell dimensions. Of course, the hardware package is our 1001 Series- including both straight and boom cymbal stands, snare and hihat stands, and BP-1001 dual chain drive bass pedal. The rack toms are isolated with a RIMS-type suspension mounting system, and lugs, brackets and mounts,etc. are likewise isolated from the shells. After just a few minutes behind this new set, you're sure to be asking yourself, "What makes those other drum sets cost 5 times as much?" We've been wondering too.....
http://www.sunlitedrum.com/drums/productpages/Studio.htm
Gracias saludos
por el 19/03/2006
Porfavor como la ven, necesito tener una apresiación, no podre probarla eso si.
9 ply maple / basswood shells
Transparent lacquer finish
New suspension system
New design stands
Dual chain drive bass pedal
2.3 mm super hoops
Natural wood bass hoop
Snare stand with ball & socket and locking arm
Snare strainer with new lateral throw and micro-adjust
Upgraded lugs with isolation system
Hi-hat stand with spring tension adjustment
Bass Drum: 22" x 16"
Tom Tom: 12" x 10", 13" x 11"
Floor Tom: 16" x 16"
Snare Drum: 14" x 6 1/2"
Cymbal Stand: CS-1000
Hi-Hat Stand: HS-1000
Snare Stand: SS-1000
Bass Pedal: BP-1000
Cymbals: N/A
Throne: N/A
¿¿¿QUE LES PARECE???
ocki
por el 19/03/2006
Pues hombre, muy buena pinta no tiene.
Parece la tipica Jimbao "de gama alta".
La tipica historia de baswood dentro y dos capitas d arce para poder decir "Maple Made", pero que no suena a arce...
Lo demas lo tipico, nada que llame demasiado la atencion, ni negativa ni positivamente.
Las medidas personalmente no me convencen.
No creo que sea una buena compra si piensas invertir en ello mas de 300€.
"After just a few minutes behind this new set, you're sure to be asking yourself, "What makes those other drum sets cost 5 times as much?" We've been wondering too..... "
Yo tambien me pregunto porque me gaste cinco veces mas, sera que soy tonto... :roll:
«Viktor»
por el 19/03/2006
Cual es su precio?? :roll:
Fer
por el 19/03/2006
Hombre..... en las fotos casi no se ve, pero tan tan tan cutre no parece... todo depende del precio.
jorgev
por el 19/03/2006
Si, de hecho no tiene mala pinta, tiene varios detalles que me parecen interesantes (el acabado, la caja de madera con 10 lugs, los aros de madera, la suspension de los toms, etc.) ademas si es regalada...
por el 19/03/2006
Buenas, yo toque alguna vez en una Sunlite y la verdad que tan mala no me pareció.
Igual no era la de la foto... aparentemente sería un modelo inferior, o más viejo, quien sabe... pero en fin, como dicen ahi, supongo que depende del precio que tenga.
por el 19/03/2006
Bueno gracias por lo cmoentado, el precio ronda los 400 euros, la verdad es que, he visto una caja de esta marca piccolo a 40 euros, la bateria vendrá con platos.
Ahora escuche por otros lados que le llaman Sunlite (yamaha), acaso las fabricará yamaha?
bueno gracias estoy entre esa y una pearl EXR de las series medias fabricadas en taiwan, la sunlite que les digo tmb ee hecha en taiwan.
saludos haber que me dicen gracias....
intoxikao
por el 20/03/2006
A ver que te dicen??
Lo que yo si te voy a decir es que si dudas entre "eso" y una Pearl Export es que tu criterio en la batería está desorientado (de buen rollo) :wink:
No hay posible comparación entre ambas baterías, si puedes permiterte la export NI LO DUDES NI LAS COMPARES
ocki
por el 20/03/2006
Secundo absolutamente a intoxicao, no hay color, asi que si puedes hazte con la export.
por el 20/03/2006
bueno estoy seguro que una pearl EXR es mejor a esa porqueria, digamoslo asi, pero lo raro que en mi ciudad llegan baterias EXR a unos 530 euros nuevas, no se como lo hacen para llegar a ese precio.
las medidas son normales, no son esas pearls medidas pequeñas ojo, esas estan ha 350 euros.
Ahora me acerque para verlas y traen acabado de vinyl y en la plaquita dice export made in taiwan
que dicen será confiable, te digo que tienen una pinta mil veces mejor que la de la foto que les mostré.
darwin
por el 21/03/2006
pues si,la marca ya hace unos años hizo una agresiva campaña publicitaria en USA con algunos endorsers (no conocidos en españa) intentando abrirse hueco en el mercado,pero o cambian el diseño de sus batacas o no se comen un colin. el aspecto de las mismas es un poco blando y esteticamente no es que sean bonitas;eso si,si te la regalan,pues cojonudo.
por el 21/03/2006
Por las caracteristicas y la foto, no parece ser horribloe, por unos 400 € puede estar bien, aunque siempre es mas fiable una marca conocida, y una export es una apuesta segura, yo no dudaria entre ellas
por el 21/03/2006
vale la pena aclarar que la de la foto es la series más alta que sacó Sunlite, talvez la que me quieren regalar sea una a dos series más bajas y ahi si que no estaria mejorando nada de lo que ya tengo, y la idea siempre es mejorar no creen?
ahora creen que haygan imitaciones de pearl, Aqui encuentro unas pearl made in taiwan. las veo y tienen todas las caracteristicas de una pearl original.
saludosss les anuncio que voy seriamente por una Pearl ELX o una Yamaha stage custom, quiero mejorar de lo que ya tenía.
saludosss
R_Diaz
por el 21/03/2006
saludosss
Creo que excepto las Masterworks, todas las Pearl se hacen en Taiwan.. al menos todas las gamas hasta la Session se hacen en Taiwan.
