Ayuda con megadrum
davidlopes
por el 09/01/2009
Hola alguien sabe de esto?, busco un modulo barato para tirar samplers con el pc.He estado mirando el Alesis trigger I/O dime que te parece y si me sirve para esto
este modulo consta de 10 inputs me he bajado el manual en ingles pero no me entero de 2 cosas
1.Puedo poner platos con 3 zonas y choque? o solo me admite 2 zonas y choque?
2.En las instrucciones me sale 1 input solo para hit hat y otro que pone esto
INC/DEC pedal input – Please connect a dual footswitch button to this input. Using this
footswitch input allows you to remotely increment and decrement values from your dual
footswitch.
esto es para el doble pedal que quiero poner? si es asi tendria 1 input mas libre para poner cualquier otra cosa?
[left]Aqui te dejo algo que sale en el manual no se si es lo de los triggers...
You can select the type of trigger you are using in the Trigger Type function. There are
many different types of triggers available on the market today – too many to cover
individually in this manual – but most triggers can be grouped into the categories outlined
below. Please consult you trigger devices’ documentation to find out which of the following
categories best fits the device.
If you have a single zone drum trigger, then ignore the “ring” column in the table below.
Select PP if you have a piezo trigger or SS if you have a switch trigger.
If you have a dual zone drum, then use a TRS cable and select the appropriate type from
the table below. If you have a dual zone drum but only a TS cable, then you can still use
the primary zone (tip) but not the secondary zone (ring).
Please make sure that your trigger’s Trigger Type is configured correctly before editing or
using it. If the Trigger Type is configured incorrectly, your trigger may not function properly
or at all. You will need to select a Trigger Type which matches your specific trigger, as
shown in the table below. Once you have finished configuring the Trigger Type, exit
Trigger Type mode to resume playing.[/left]
[left]TRIGGER TYPE TIP RING[/left]
[left]PP PIEZO PIEZO
SS SWITCH SWITCH
PS PIEZO SWITCH
SP SWITCH PIEZO
SUS SWITCH
AS SUSTAIN PEDAL*
HH HI-HAT PEDAL**[/left]
[left]*To be used with footswitches. When the footswitch is pressed down, it generates
a sustain message (MIDI CC 64). When it is depressed, it cancels the sustain.
**Hi-hat foot pedals will automatically be detected[/left]
so there is no need to set a Trigger Type.
teniendo en cuenta esto cuantos aparatos y con cuantas zonas podria llegar a meter en este trasto y que me aconsejas lo quiero pillar todo en thoman.
llevo semanas mirandome este tema pq quiero customizarme una bateria electronica y necesito un entendido en megadrums, Busco poner 3 o + platos con 3 zonas a ser posible y choque y el snare y los 3 toms con 2 zonas para hacer el efecto aro y malla, cual es el tope de cosas que puedo meterle? gracias de antemano.
por el 09/01/2009
Si lo quieres todo con 2 zonas, el máximo van a ser 10 cacharros. U 11, si alguno puede ser de una zona (aprovechando la otra de donde iría el bombo, que no tiene sentido ponerle 2 zonas).
Lo que dices del footswitch pedal es para un pedal que se use para subir y bajar de programa (como un botón, pero en el pie para activarlo más fácilmente).
Y lo de los platos con 3 zonas y parada... en qué modelo de pad estás pensando?
davidlopes
por el 09/01/2009
Gracias tio
en los yamaha pcy-155 funcionaria con el modulo alesis trigger i/o? es que me hago la pixa un lio con lo de piezo/piezo - piezo/switch no se que es tio,,, no entiendo eso. de todo lo demas se que se puede hacer una U y poner uno de esa manera.
me molaria poner platos tipo alesis surge que son en acabado dorado como los platos reales pero no encuentro ningunos que pueda comprar con 3 zonas y parada que no se disparen, me conformaria con los yamaha pcy-155 pero no encuentro información de nada tio... si me aseguras que me iran y me das buenos argumentos me lo pillo ya y a tomar por .... jejej, gracias tio me estas ayudando mucho, eres un solete ;)
por el 09/01/2009
Qué es eso de la U?? O_O
Respecto a los platos de 3 zonas con parada, lo pregunto porque no encuentro modelos de platos así, el Yamaha PCY-155 tiene 3 zonas, pero no pone nada de parada. De hecho es lógico; el switch que los Roland usan para la parada, los Yamaha lo usan para la tercera zona...
Lo de poner un plato de 3 zonas en el Alesis, mañana te lo miro, que ahora me voy a dormir, y puede ser harto largo buscar esa información ;)
De nada, para eso estamos ;)
davidlopes
por el 09/01/2009
Ayer estuve en una casa de musica tocando con una DTXPRESS IV el plato tiene 3 zonas y parada el PCY-155 la historia es si con ALESIS también o el modulo de yamaha tiene algun proceso interno dile como quieras que hace q por soft pille eso por su propio módulo y saque 3 + parada. me podrías explicar que significa lo de piezo/piezo piezo/switch y switch/switch? porque el modulo ALESIS TRIGGER I/O admite configurar cada input con esas tres caracteristicas... van por ahi los tiros verdad? de las zonas... gracias tio por echarme una mano.
mirate esto lo he encontrado supongo que es la clave pero mi ingles es very poor.
[left]Alesis Technology Note[/left]
[left]Alesis Technology Note Trigger IO- Information about trigger types-July 18, 2007 Page1 of 2[/left]
[left]Trigger IO Information about Trigger Types[/left]
[left]Here’s a basic explanation about the difference between various trigger types.
The basics- How the pads work
Piezo pickups are like microphones. They transmit the acoustic information of the pad
being struck into electrical impulses. Piezo’s are good sound transducers, however they
are susceptible to picking up other pads being struck (this is called Crosstalk.) Piezo
pickups are embedded into the drum pad and the trigger information is converted into
MIDI signals in the drum module (DM5 and Trigger IO.)
Some drum pads use switches on the edges which send out impulses that are converted
into MIDI information. However this information doesn’t have the ability to be velocity
sensitive like Piezo’s. Older drum kits like the Roland TD-7 and some current Roland
Pads have switches as well (Roland PD-9.) While this can eliminate Crosstalk issues it
does limit the functionality of the trigger. The majority of professional drum pads use
Piezo triggers on both zones because of the limitation of switch triggers.
How the Trigger IO works
The Trigger IO is designed primarily to use Piezo trigger inputs on both zones since this
works better for the user. We also have some very sophisticated Crosstalk adjustments on
the module to make to Piezo’s work on one trigger pad.[/left][left]Alesis Technology Note[/left]
[left]Alesis Technology Note Trigger IO- Information about trigger types-July 18, 2007 Page2 of 2[/left]
[left]The trigger IO’s inputs are TRS (tip ring sleeve.) This means you can send two triggers
(dual zone) to each input. All of the inputs except for input #4 are design for Piezo/Piezo
trigger inputs. Electrically you can have only one or the other. We choose to work with
the newer/better type of triggers for dual zone control. If you plug in an older drum pad
with a piezo/switch configuration the center zone will work fine, however the edge
switch trigger won’t work unless you plug it into input #4 .
Note: Some electronic cymbal triggers have a switch for a bell trigger. For this we made
input #4 accept Piezo/Switch inputs so these cymbals will work. This would apply to
Pintech and Roland electronic cymbals.
Just to confuse you more, our inputs will work with most electronic cymbals that have a
switch mounted underside the cymbal the sends a message to choke a sound. This
replicates the effect that you get when you hit a crash cymbal and then grab the edge.[/left]
This basically shuts off the sound on a module or software.
